jstarke | -- 09-29-2016 @ 2:35 PM |
I've heard that a T-5, 5 speed from a Mustang will bolt right up to my 47 super deluxe with a flat head V8. Is it that easy? If it is does anyone know what years, models, etc... wil work. Do I have to change the input shaft? I assume the torque tube would have to be replaced?
40cpe | -- 09-30-2016 @ 5:51 AM |
No, it isn't that easy. It will take an adapter and part manipulation to mate it to the engine. Someone makes an adapter to get you started converting the T-5 to torque tube but the tube and drive shaft have to be shortened. Otherwise you will have to open the center of your frame X-member and convert the rear to open drive.
carcrazy | -- 09-30-2016 @ 4:13 PM |
Here is an article about swapping a T5 transmission into a Model A that you might find of interest. http://lainefamily.com/ModelAFiles/ModelAT5.htm
jstarke | -- 10-02-2016 @ 6:20 AM |
I figured it couldn't be that easy. Thanks
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10121 |
