Dipper005 | -- 09-21-2016 @ 7:57 AM |
Hi guys. Another question, this time it's about why when I'm cranking over the engine to start, it turns over slowly and also makes a loud clicking sound. 1948 V8 Flathead, rebuilt starter, new selanoid , all connections clean. Still 6 volt positive ground. Thanks for any help.
pauls39coupe | -- 09-21-2016 @ 8:41 AM |
Remove the fuel pump, see if that is the source of your noise.
Dipper005 | -- 09-21-2016 @ 8:54 AM |
I will. Just wondering why I don't here the clicking while it idles?
TomO | -- 09-23-2016 @ 7:03 AM |
Do you have the correct 6 volt cables from the battery to the solenoid and to the starter? Tom
Greg58 | -- 09-24-2016 @ 4:35 AM |
If you only hear the clicking while the starter is engaged you could have a chipped drive gear on the starter. Greg
51f1 | -- 09-25-2016 @ 11:51 AM |
I'd look at the starter and flywheel gear. Richard
lazy69ranch | -- 09-25-2016 @ 4:00 PM |
I wonder if a video of the problem would capture the sounds. Would be interesting to be able to help others troubleshoot using a YouTube video link.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10097 |
