36fordor | -- 09-16-2016 @ 9:07 AM |
Where is 35 Ford coupe brake light switch? How do I access & remove it? Thanks. This message was edited by 36fordor on 9-17-16 @ 8:33 AM
nelsb01 | -- 09-16-2016 @ 9:48 AM |
If original, it should be at the base of the brake pedal. You should also be able to follow the green wires to the switch.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10085 |
