fordv8j | -- 08-31-2016 @ 6:19 AM |
My left horn blows weak,if I disconnect the right horn,then the left is ok,the wireing is new,all terminals soldered,hooked left one direct to battery still won't work.....are there anyone that repairs them??
TomO | -- 08-31-2016 @ 9:33 AM |
Check to see that the horns are properly grounded. If it is disconnect the battery and remove the cover over the horn motor and clean the set of points. Reassemble and try the horn. Tom
fordv8j | -- 08-31-2016 @ 12:55 PM |
Took horn off,took top off filed points,didn't help,tried to adjust points,broke the adjustment nut off,,so I gave it a heart transplant from another horn into my correct case...the original apparently had water in it at some time....rusted...Thanks to all
ford38v8 | -- 08-31-2016 @ 6:39 PM |
James, you have a good heart! Alan
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10038 |
