fenbach | -- 08-25-2016 @ 8:59 AM |
I have a '37 block and '36 heads and water pumps. with plans to build/rebuild an engine. are '36 heads and pumps as good as '37s? surely henry thought the '37 design was an improvement over the '36 but maybe not??
ford38v8 | -- 08-25-2016 @ 10:54 AM |
From a functionality viewpoint, the '37 is better, as pushing cooled water from the bottom is more efficient than pulling heated water from the top. The blockoff plates to convert a '37 to a '36 system were offered only as a cost savings to owners when buying a replacement short block, the savings being the cost of new heads to go with the '37 block. Alan
fenbach | -- 08-25-2016 @ 11:19 AM |
The '36 pumps are skip haney rebuilds. Water flow is impressive. Any other reasons to "upgrade?"
nelsb01 | -- 08-25-2016 @ 12:22 PM |
The 37 block will have insert bearings -- that is a great reason right there. One would presume that this is going into a 1936 -- so, you will need 37 water pump block offs. Some would say that the water flow from the middle of the heads (1937) was an improvement for cooling. But, back in the mid 30s replacement of newer engines in older vehicles was standard FoMoCo dealer repair procedure.
ford38v8 | -- 08-25-2016 @ 12:24 PM |
I think you've got it covered, and only a sharp eye would notice that your block is a '37 rather than a '36. As a bonus to keeping the block off plates, you can point to them as proof that your engine has insert bearings when some know-it-all asks how you know it doesn't have babbitt bearings. Alan
VT/JeffH | -- 08-26-2016 @ 7:10 PM |
Hi Everyone, I'm a noob, and this just my opinion but... 1937 Block with pumps in block, very nice, inserts and cooling. 1937 Block with pumps in heads, nice, inserts. Owner of 1936 Phaeton with pre-37 replacement block. 1935 Fordor with post-36 block. And a spare 37-ish. -VT/JeffH club site WWW.NCR36.COM This message was edited by VT/JeffH on 8-26-16 @ 7:23 PM
JM | -- 08-26-2016 @ 9:17 PM |
Another plus for a '37 block is the cylinder wall thickness is greater than the earlier 21 stud blocks. The original bore of 3-1/16" can usually be safely increased to 3-3/16". Maybe add a 4" Merc crankshaft and a few other performance enhancing items, and you can have a little power house engine in the same league as the later 24 stud engines. John
ford38v8 | -- 08-26-2016 @ 10:14 PM |
I think more to the question of which heads to use, your options are to use funky looking flex hoses on the '37 heads, or to use the '36 heads with correct hoses. ...This, of course, due to the different location of the outlets, center on '37, and front on '36. Alan
JM | -- 08-27-2016 @ 7:31 AM |
Those funky looking flex hoses were never a good thing to use when putting a 37 to 48 flathead engine in an earlier 32 to 36 V8 Ford. Gates makes an upper hose that works perfectly for this conversion. Also, Drake is now offering their hose kits for this conversion. John
Sneezer | -- 08-27-2016 @ 4:44 PM |
I am currently doing this exact conversion. Can anyone provide the Gates hose number for me? Thanks: Arnie
Larry Lange | -- 08-28-2016 @ 1:57 PM |
If you're converting to the flex-hose option to connect to the 37 heads, are you also changing the outlets at the top of the 36 radiator (the originals point downward at a sharp angle to connect to the original water pumps at the front of the cylinder heads)? I have a 59 engine in my 36 and I had the radiator outlets altered to point back level to the ground, so the flex hoses loop gently back to the inlets at the center of the engine. It works fine. Without the change the hoses would have had to make two sharp turns, first down one direction, then back, then down n another direction, before they connected to the engine; I didn't want to do that. Larry Lange Puget Sound Regional Group
JM | -- 08-28-2016 @ 9:07 PM |
Larry, no need to change location or position of top radiator inlet tubes on 35/36 when installing a 37-48 FH engine with center outlet heads. Here is one of many posts on Fordbarn on this topic. If you do a search there for "gates hose" or "gates top radiator hose" these posts will be found that include all the information you need. http://www.fordbarn.com/forum/showthread.php?t=157291&highlight=gates+hose&showall=1 John This message was edited by JM on 8-28-16 @ 9:08 PM
ford38v8 | -- 08-28-2016 @ 9:28 PM |
Found it: Gates 21253 used in conjunction with a NAPA hose adapter 902. Flex hoses are criminal. Alan
VT/JeffH | -- 08-30-2016 @ 2:22 PM |
Clipped this from FordBarn member Ed Pitts's post. -VT/JeffH club site WWW.NCR36.COM
JM | -- 08-31-2016 @ 6:28 AM |
One thing I learned a long long time ago about those spiral wound looking flex hoses,....when you try to make them conform to unusual twists, bends and turns between head outlets and radiator tank inlets, they will cause an undo strain at the soldered junction of tubes to tank, and could cause a failure, and usually at the most inopportune time. I would never recommend that anyone use them. John
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10018 |
