twostickmutt | -- 08-20-2016 @ 4:31 PM |
is it alright to mount an oil filled tube coil facing down or do they have to be facing up ? i have the coil adapter for the helmet dizzy i can use and want to mount a tube coil on the firewall till i can get the original sent out to skip in Fla. thanks. This message was edited by twostickmutt on 8-20-16 @ 4:31 PM
MG | -- 08-20-2016 @ 5:24 PM |
When I did this on my '34, I laid the coil on its side and mounted it to the frame rail...No problem....
35ford | -- 08-21-2016 @ 2:30 AM |
Sending coil to Fl. will only take a week fom my expeience. I have just laid a temp coil between the head and intake. Worked for me. jmo.
trjford8 | -- 08-21-2016 @ 7:08 AM |
Should work facing down. They did it on all Model As.
twostickmutt | -- 08-21-2016 @ 7:59 AM |
thanks for all the replies.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10004 |
