0ld38 | -- 05-12-2016 @ 10:42 AM |
Anybody have any helpful hints to get a old style crankshaft pulley off. It has no nuts/bolts. And by old style I mean it has the old crank that you turn.
TomO | -- 05-13-2016 @ 7:31 AM |
The back part of the crank ratchet is a nut. The crank nut can be removed with a 1 1/8" deep socket. Put the truck in the highest gear and turn the nut counter clockwise. Most of them come off this way. If you can't get it off this way, you may have to remove the radiator and use an impact wrench. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=9660 |
