Redford53 | -- 06-28-2015 @ 10:43 AM |
I have a 1953 Ford f250 truck and I like to purchase mags and new tires . it has 8 lugs pattern any suggestions , also it has 6 volt battery can you use a 12 volt jump starter?
flatheadman | -- 06-29-2015 @ 9:19 AM |
If it is the eight bolt pattern, most any later eight bolt wheel should fit. Take a wheel to any tire store and they will measure the pattern to be sure. They have a tool for that purpose. As for using 12 volt to jump start, look for the discussion concerning that subject within the last month on this forum.
Redford53 | -- 06-29-2015 @ 5:05 PM |
thanks for your response flatheadman This message was edited by Redford53 on 6-29-15 @ 5:05 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=8675 |
