PeterFord | -- 03-08-2015 @ 7:07 PM |
Are the gas caps vented? My garage seems to have the scent of gas in it. Everything seems tight. Is this normal?
TomO | -- 03-09-2015 @ 9:39 AM |
The gas caps are vented, but I would look carefully around the fuel pump and carburetor for signs of a leak. Also check the hose from the filler neck to the tank and the gas line from the tank to the firewall. Tom
PeterFord | -- 03-09-2015 @ 1:30 PM |
Tom: Many thanks. Several bolts on the carb were loose. Really appreciate that! Thanks. Peter
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=8295 |
