Larry T | -- 02-08-2010 @ 4:58 PM |
I would like to know how to take the heater switch apart. the control nob so i can take it out of the bracket belo the dash thanks Larry
trjford8 | -- 02-08-2010 @ 7:05 PM |
Those knobs are usually connected to the shaft with a small set screw. If you don't see a set screw in the shank of the knob then it is held in with a spring that fits into a groove on the switch shaft. If this is the case then pull straight back on the knob and it should come off.
Larry T | -- 02-10-2010 @ 12:06 PM |
thanks Iguess Iwas not applyihg enough forse Larry
51f1 | -- 02-16-2010 @ 3:21 AM |
My '51 heater switch knob screws onto the threaded shaft. There is no set screw. If your switch is the 2-speed Arcless switch, it's just like mine. If it is stuck, pull the shaft out, grip it w/pliers and unscrew the knob counter clockwise. Richard
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=776 |
