g2photo | -- 07-05-2014 @ 11:39 AM |
I need to take out the radiator on my '37 Panel. Have never done this and wondering if I need to remove the fenders before I can remove the radiator.
shogun1940 | -- 07-05-2014 @ 2:21 PM |
You should not have to remve the fenders,, cut the bottom hoses in half if you are not going to reuse them. there should be two mounting bolts 3/4 of the way down , there might be some side bolts to loosen and slide out and then its a matter of sliding it up and out.. put a piece of thick cardboard in front of the fins. have fun and good luck
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=7482 |
