jr4726 | -- 01-30-2010 @ 3:52 PM |
iam restoring an old ford truck. i have what i think is the vin. could someone tell me how i can find what the numbers an letters mean. i think this is a 48 or 49 ford 2 ton truck but i need to know for sure.
Big Red 51 | -- 01-30-2010 @ 6:44 PM |
Jr, Post the numbers you have and then we can give you some info. Don
jr4726 | -- 01-31-2010 @ 5:44 AM |
ok thanks this what i have. 799ii4268i6 this is the vin on the frame an transmission. iam not sure hon accurate this is,the letters iam not sure if they are correct an the second nine iam not sure of. the numbers on the head were 59a-b and the number on the engine was b3733 with a big 59 under it. thanks for the help. Ed
trjford8 | -- 01-31-2010 @ 8:04 AM |
Is there an ID plate inside the glove box door?
jr4726 | -- 01-31-2010 @ 9:03 AM |
this is just a chassis. i do not have a cab yet. i am trying to pinpoint what this is so i can get the rite year cab for it
TomO | -- 01-31-2010 @ 9:58 AM |
The serial number that you posted is for a 1947 vehicle. The i is read as a 1. Your serial number should read 799A-1,426,816. The 59 is for an engine built between 1945 and 1948. Here is a link to the serial numbers by year of Ford products. http://www.vanpeltsales.com/FH_web/flathead_serialnumbers.htm Tom
51f1 | -- 01-31-2010 @ 1:57 PM |
I don't understand how that list can apply to '48 trucks which use the 8RT (8BA) engine. Richard
ford38v8 | -- 01-31-2010 @ 2:26 PM |
Richard, you are correct regarding the '48 truck engine. The chart doesn't address that difference. Ed's truck, however, is a '47, which does have the 59 engine. Alan
jr4726 | -- 01-31-2010 @ 2:56 PM |
thank you very much for the info. the only correction is instead of an a it is a t at the end of the 99 for a 1 1/2 ton truck. Ed
jr4726 | -- 01-31-2010 @ 3:00 PM |
is there any way i can find out more about the engine and transmission with these numbers i have
51f1 | -- 02-03-2010 @ 6:51 AM |
The list implies (or says) that it covers all cars and trucks. I just wanted to be sure i wasn't missing something. Richard
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=710 |
