unclemark | -- 10-27-2013 @ 7:41 PM |
Doing brakes on my newest project and will start on the rears soon, anybody know if the drums will come off separately or do I have to pull the entire hub? (Rear axle)> Thank you.
supereal | -- 10-28-2013 @ 6:50 AM |
On larger trucks with the full floating type, the axles come out first. Unbolt them from the hub and pull them out. Then you can remove the large nuts that hold the hub to the housing. Don't forget to back off the brake adjusters to allow the hub to be taken off the housing.
unclemark | -- 11-07-2013 @ 6:19 PM |
Thank you, got all of them apart and ready to put back together.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=6661 |
