396stan | -- 08-20-2013 @ 10:14 AM |
Does anyone know how to get the pulley off of a water pump for a 47 flat 6 ? Found a new pump at Kanters but I can't separate the pulley so I can send in my core . Thanks in advance . Stan
supereal | -- 08-20-2013 @ 12:49 PM |
The pulley is held on by the four bolts that attach the fan. You can see both the "G" and "H" pumps on page 387 of the green book.
396stan | -- 08-20-2013 @ 3:30 PM |
I guess I meant the hub that the pulley bolts to . Will this come with the new water pump?
396stan | -- 08-20-2013 @ 3:41 PM |
How can I get my hands on the green book? I have the 41-48 Ford book .
supereal | -- 08-20-2013 @ 5:34 PM |
The hub should come with the new pump. The green book is widely available. A good source is C&G. www.cgfordparts.com
trjford8 | -- 08-20-2013 @ 7:55 PM |
I believe he has the early pump and the pulley is pressed onto the shaft. It's a cast pulley and may be difficult to get off. I had one of these a few years ago. I went to Napa Auto Parts and bought a new pump that that had the hub and then went to the local "bone yard" and found a pulley that would work on the hub.
396stan | -- 08-21-2013 @ 4:40 AM |
I got my pulley off , it is just bolted on , I was worried that my new pump would need my old hub . I didn't want to send off my core with parts I would need . I'll wait for my new pump and see what I need . Thanks Stan
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=6434 |
