windjamer | -- 01-08-2010 @ 1:22 PM |
Has any one taken the stearing box out of a 32 pickup with the original V8? And if you have, what did you have to do with the engine in order to get clearince to remove the stearing box?
Stroker | -- 01-08-2010 @ 1:59 PM |
As I recall, (it's been 50 years), all I did was pull the steering wheel,and woodruff key,un-clamp the column from the box, remove the pitman arm, and pull the box and steering shaft down and forward. This was over a service pit, so there was lots of room. A service hoist would have worked as well.
windjamer | -- 01-09-2010 @ 8:21 AM |
Thanks for your help.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=576 |
