Dano | -- 02-17-2013 @ 10:08 AM |
I have 5 BB 1225 rear wheel bearings for 31-34 trucks. These are NOS that I got from a Ford dealership going out of business in the 70's. They have always been inside a building but due to temp. change etc. they have some surface rust on some of the rollers. When I use very fine steel wool to remove the rust the metal is discolored but not pitted. Can I use these or are they toast.
Stroker | -- 02-17-2013 @ 10:45 AM |
As long as there are no pits, they should be fine to use.
supereal | -- 02-17-2013 @ 11:28 AM |
Check to see that the BB-1225-A bearings, side to side, measure 1 3/4" long. They were designed for trucks, but the passenger and "commercial" (light trucks) used a bearing 1 23/32" from 28-36. They would be B-1225-A. Close, but different. If you clean the bearings with steel wool, be very careful to get all the residue out of the rollers.
alanwoodieman | -- 02-17-2013 @ 1:40 PM |
clean off the grease and then soak them in Evapo-Rust, works great. Can get evaporust from just about any good paint or hardware store
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=5743 |
