madsonic | -- 02-09-2013 @ 3:13 PM |
Got a bud restoring his '34 pickup and got stuck on what the books are calling "sodium tallow soap" to lube his u-joints. Anybody got an idea of something modern he can pick up that will do the trick?
Stroker | -- 02-09-2013 @ 3:54 PM |
madsonic: Try clicking on this previous thread..//www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=4536&keywords=U-Joint%20lube%20grease
supereal | -- 02-09-2013 @ 8:31 PM |
We use Mystik JT-6 grease for u-joints. It is a sticky waterproof grease that will not "hollow out" or emulsify with the usual transmission oil that escapes into the u-'joint chamber. If starting from dry, plan to pump in about two tubes.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=5709 |
