randeyc | -- 12-25-2012 @ 12:45 PM |
Does anyone have a photo of the location of the Patent Data plate and the Body Number tag? Looking for placement on my 37 PU. Thanks for your help.
trjford8 | -- 12-26-2012 @ 7:38 AM |
I don't know if the pickup had a body number plate. Unless you replaced the firewall or someone welded the holes closed, you should be able to see the four small mounting holes for the patent plate. It's usually on the vertical part and driver's half of the firewall.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=5558 |
