36 conv sedan | -- 12-28-2009 @ 9:21 PM |
Hi: Would anybody have available any of the following parts?: 1. Headlights. Are they the same from '32 to '34? 2. Wheel,one, for my spare tire. 3. Wheel rings, three 4. Water pumps, two 5. Spare tire holder under chassis 6. Air filter. Same as in the cars? 7. Horn. What model did they use? Thanks, Victor
TomO | -- 12-30-2009 @ 7:20 AM |
Victor, you should post your list in the classified section of this forum and the classified section of the Ford Barn. You will probably get better results that way. Tom
trjford8 | -- 12-30-2009 @ 7:54 AM |
Victor, along with TomO's suggestion here's some information.The headlights are the same on the 33-34 commercial. 32's are different. You can buy new repo headlights from Drake or other suppliers.When you consider the price of parts to fix old headlights you are better off buying the new ones. The air filter is the same as the car. There was an accessory air filter used on commercials that was an oil bath filter. They are not easy to find. The 33-34 used the "beep" type Sparton brand horn which had a bracket that mounted it under the left headlamp. This horn was also used on the 32's. This message was edited by trjford8 on 12-30-09 @ 7:56 AM
36 conv sedan | -- 01-02-2010 @ 11:19 PM |
Thanks to both for the suggestions and information! I will look for the web address of the places to put my ad. I am very interested to get the truck done and back to as close to original as possible. Thanks again! Victor
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=513 |
