SteveF | -- 08-25-2012 @ 6:39 PM |
Hello all..working on a 37 1/2 ton PU and am missing the lower radiator splash. I have search high and low with no luck...they are not reproduced...any help would be appreciated. Steve
trjford8 | -- 08-26-2012 @ 10:38 AM |
Steve, put an ad on Fordbarn and also place an ad on this site. You are correct, they are not reproduced. Also check some of the vendors who advertise on this site.The Early Ford Store in San Dimas, Ca. has lots of NOS and good used parts. Also try All Ford Parts in Campbell, Ca. They also have a lot of good used parts.
SteveF | -- 08-27-2012 @ 5:22 PM |
Thanks... will give them a try. It is a tough one to find. Steve
42oink | -- 09-26-2012 @ 7:22 AM |
Hang in there, Steve. If you're not opposed to repro parts, I talked with Bob Drake at the National meet and there might be one coming in the near future. In the mean time, if you come across an extra, keep me in mind. Good luck with the truck.
supereal | -- 09-26-2012 @ 9:18 AM |
The sheet metal surrounding the radiator is designed to direct air to enhance cooling. This is why many models have seals around the edge to improve the use. There are lots of repros out there for 33-34 and 36, I haven't seen others. Many were lost over the years when the shade tree mechanics tossed them away.
SteveF | -- 10-01-2012 @ 2:16 PM |
Thanks to you all....I was able to come up with from a posting on Ford Barn...
SteveF | -- 10-01-2012 @ 2:19 PM |
Hi 42oink... you you tell me in another post that you might have the cowl vent hinges, levers and bracket??? I will be going to Carisle and Hershey...anybody there that might have a better probabilty of have these?
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=5106 |
