Super Delux | -- 11-22-2011 @ 6:53 PM |
how do you remove the ignition lock cylinder from a 1946 Ford Super Delux, and also relpace it with a new one?
supereal | -- 11-22-2011 @ 6:58 PM |
There is a "break off" pin that secures the lock cylinder. It must be removed, usually by drilling. If you look carefully, you will see it. If you are lucky, you can drill a hole, then insert a screw, and pull out the pin. Most new locks are furnished with a new pin.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=4007 |
