waynearnyF3 | -- 11-23-2009 @ 11:12 AM |
Everyone, I'm looking for a source for both battery cables for my 1951 F-3 with a V-8 in it. The positive ground cable is about 18" long, but I could use a slightly longer one. The one in there now still has the old FoMoCo label on the pos post fitting! The negative one that runs off the negative post is about 14" long, but on that a shorter one would also work. Thanks. Wayne Arny
supereal | -- 11-23-2009 @ 11:48 AM |
You can order the correct cables from C&G (800/266-0470) for your truck. The battery to solenoid cable is 8A-14300-NS.
waynearnyF3 | -- 11-23-2009 @ 4:23 PM |
Thanks! I'll give them a call. I did get a response from Early Ford V8 Sales Inc., and they had the parts from a 51 car, which were longer than my current parts, but only by a couple of inches. Now I'll have two sets, if your recommendation has the right parts! ![]()
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=359 |
