jameson5938 | -- 03-23-2011 @ 5:29 PM |
I know there are several companies that sells parts for my 37 pickup, but have yet to find someone who has the stainless trim that goes around the hood louvers and the part that connects to two wipers. ANY suggestions??? James A. Westbrook
trjford8 | -- 03-23-2011 @ 7:10 PM |
Jim, the stainless is not reproduced to my knowledge. Generally the wipers are two separate motors mounted in the header panel. If you have just one wiper motor that will be running a second wiper mounted with a "dead man" you will probably have to buy the entire kit.Your only other option is to make the connecting rod. The wiper kit with the new rod is sold by Sacramento Vintage Ford.I suspect other vendors also carry this same kit.
37RAGTOPMAN | -- 03-24-2011 @ 4:46 PM |
you need to find a second wiper motor for the right side, it goes in the header panel, Deluxe pickup had 2 wiper motors, I am pretty sure they are the same as the pass cars, 1937,1938,1939 that wiper set up with the connecting rod was only for 1935-1936 as far as I know, and the repros set up are junk, I installed one on a customers car it was very cheaply made. thiss was 15 years, maybe the newer ons are better, also in the header of deluxe trucks there was a domelight with a little switch, do a little reserch on what you want to do,so you do not make any mistakes hope this helps 37 RAGTOPMAN
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=2796 |
