clock47 | -- 03-04-2011 @ 11:55 AM |
Have a 1947 1 ton with a regular box. Recently re-installed the cab which has been off for several years. I have found a container markes "rear cab bolts" which contains 2 bolts (1/2 in dia x 5 in long with 1 in x 1&1/2 in long coiled springs attached) The springs seem pretty heavy duty. The QUESTION is about the springs - WHAT AND WHERE DO THEY GO?? Under the bottom of the cab wood mounts?? THANKS for any info!
alanwoodieman | -- 03-05-2011 @ 8:32 AM |
they go on the frame attachment points, not under the wood, they allow the cab to move on the frame as it flexes under load
clock47 | -- 03-07-2011 @ 2:09 PM |
can you be more specific?? Between the wood and the cab or between the wood and the frame? 1 spring at each of the 6 total wood shims?
alanwoodieman | -- 03-08-2011 @ 7:56 AM |
bolt goes thru cab floor, thru wooden block, thru frame attachement point, I say this because some are thru the frame others are thru a bracket attached to the frame, place spring, then flat washer, then bolt, snug up but allow for some spring movement, then insert cotter key, bend ends to secure
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=2698 |
