alanwoodieman | -- 12-16-2010 @ 1:32 PM |
can anyone please give me the length of the mirror arm for a stake bed truck. My current ones are 8 1/2" from hinge to mirror bolt hole. I need the longer ones
Stroker | -- 12-16-2010 @ 3:09 PM |
Alan: I have a mirror arm that I took off our 40 when we installed a dump box, and "West Coast" mirrors in the late 50's. I'll dig it out of the barn tomorrow and measure it for you. It's quite a bit longer than 8-1/2", and appears to be made out of malleable or cast iron, has no curve to it and the mirror head and hinge mount appear to be the same as the mirror on my 38 wagon (work-in-progress) pictured, except not plated. The only reason I kept it was in case I ever wanted to pull a trailer with my 38 (not likely). Dan
alanwoodieman | -- 12-16-2010 @ 8:27 PM |
Stroker that would be great, nice looking woodie, I have a 40 wagon and am working on 41 3/4 ton stake bed. The original mirror arms are not swan neck style just straight. I guess I am going to extend the short ones that I have to be able to see around the bed.
Stroker | -- 12-17-2010 @ 2:18 PM |
Alan: This mirror arm measures 19 inches from the top corner of the hinge, to the eye at the mirror head. It is straight, tapered, and has an oval cross-section (oriented like an airfoil), that measures .575 x .725 at the hinge end, and .380 x .400 at the eye end. The mirror is a "nominal" 4", and appears to be the same as passenger mirrors of the same vintage. The hinge yoke has a 2-inch opening, which is smaller than my 38 woodie which measures 2.125. Dan
alanwoodieman | -- 12-17-2010 @ 8:14 PM |
Dan , thanks for the info, I will check in the am and let you know Alan
alanwoodieman | -- 12-18-2010 @ 10:26 AM |
Dan, my 8 1/2 arm measures very close to your long arm, .595 x .747 and .397 x .387 at the end, also has a 2" hinge opening. Thanks for your help. PS if you consider selling I would like to purchase.
Stroker | -- 12-18-2010 @ 1:06 PM |
Alan: Check your email. Dan
alanwoodieman | -- 12-18-2010 @ 7:21 PM |
Dan ,just found out my e-mail was not sucessfully updated--I have tried to change it again, but alan48@charter.net is the new e-mail, sorry others have been having trouble getting me and a friend called and told me my e-mail had not changed. Alan
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=2312 |
