Ima | -- 08-08-2010 @ 7:10 PM |
On my flathead engine where does the accelerator return spring connect between? On mine one end connects to the accelerator rod and the other end should connect near the carb somewhere, but I don’t know where. Is there a picture somewhere that I can look at? All the parts catalogs show an exploded diagram, so they don’t help any. Thanks in Advance Willie
51f1 | -- 08-10-2010 @ 6:54 AM |
There is a bracket bolted to the back of the carb. One end of the bracket supports the choke cable and the other end supports the throttle cable. There is a small hole in this bracket between the choke and throttle cables that the spring connects into. I forgot that I had a picture of the bracket. Perhaps this will help. You can see the hole for the spring in the bracket: http://i250.photobucket.com/albums/gg264/rcrispd/PB040133.jpg If you look at this second picture, you can almost see where it attaches to the carburetor: http://i250.photobucket.com/albums/gg264/rcrispd/PA3001322.jpg Some of the brackets don't have the hole (for cars)? If you have one that doesn't, use the picture as a guide and drill a hole in it. That's what I did. Richard This message was edited by 51f1 on 8-25-10 @ 11:24 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=1677 |
