N&GJONES | -- 10-19-2009 @ 3:19 PM |
My First 36 need help with reseach on my truck, trying to restore back to original. I've got the Owners manual,Green Bible Parts,Service Manual,Service Bulletin,Mack Hills Ford Pickups. My owners manual says engine number is also the serial of the truck, found on the top of the clutch housing. My frame Number is StarBBI-28791 and the number I found by the clutch housing reads 51-7006 with w6 underneath it. Which isn't even close, not sure what this number is. I Have attached picture.Also No where can I find what my interior should look like. I've a piece of floorboard but not sure if it is correct because there is about a 1/2 inch short on each side. Thanks Nancy
RSS | -- 10-19-2009 @ 4:41 PM |
The engine number will be stamped into the trans housing above the clutch inspection cover, and will start and stop with stars. Randy
TomO | -- 10-19-2009 @ 5:02 PM |
Nancy, you are missing a few numbers in your frame stamping. It should be *BB18-######## * The ####### should be between 18-2,207,111 and 18-3,331,856. Tom
N&GJONES | -- 10-20-2009 @ 6:14 AM |
Thank you randy I will keep looking for those numbers.
N&GJONES | -- 10-20-2009 @ 8:58 AM |
Tom, I attached a picture of my frame, as you can see it only showed these numbers. I will remove the bracket and hopefully I will find the rest of my numbers. Thank you for your help.
N&GJONES | -- 10-20-2009 @ 10:05 AM |
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=165 |
