f1ford48 | -- 02-12-2022 @ 2:41 PM |
Is there a horn relay for my 41 pickup- where does it mount?
37RAGTOPMAN | -- 02-13-2022 @ 6:47 AM |
hi horn relay you need to get a wiring diagram for your truck, or better yet a OWNERS MANUAL, you woud be surprised how much info is in there, some times relays were attached to the bracket with the horns I am not sure even if you need one, does the horn work, I asume it does not, so you should test the horn off the truck directly to a battery, to see if that is a problem to start with, , I have a 37 which takes no relays, hope this helps 37Ragtopman post more INFO
rustedorrotting | -- 07-13-2022 @ 9:42 AM |
Yes there is a horn relay. Mine although it might not be original, I placed on the drivers side inner fender panel.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=15486 |
