Jeepbut | -- 10-19-2019 @ 8:51 AM |
I figured out the front and sides but the rear I don't understand. There is a cork piece that I assume is the rear gasket. How does it go in? There is a sharp narrow part of the pan at the rear that appears to go up and partly around crankshaft. Can't figure out how the gasket works. Thanks. 1947 v-8 pickup. This message was edited by Jeepbut on 10-19-19 @ 8:52 AM
Jeepbut | -- 10-19-2019 @ 2:49 PM |
It almost looks like the u-shaped part of the pan fits into a channel around the crankshaft with no provision for a gasket. ???
TomO | -- 10-20-2019 @ 8:45 AM |
If you are talking about P/N 18-6701 oil pan packing, there is a recess in the rear main bearing cap that the cork fits into. There is a drawing of this on page 215 of the 1928-1948 Chassis Parts Catalog. If you have a different Chassis Parts Catalog, it will be on the drawing for the engine. Use Hi-Tack or another gasket sealer to keep the cork in place in the slot while installing the pan. Tom
Jeepbut | -- 10-20-2019 @ 5:43 PM |
Thanks. I will look again Tuesday night and see if I can figure it out. The gasket piece that I have is not in a u-shape so I guess I bend it into a u and glue it to rear main cap?
trjford8 | -- 10-21-2019 @ 6:18 AM |
In some gasket kits that piece is in fact straight. It's fairly easy to bend it into position.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=13325 |
