catskinner | -- 05-26-2010 @ 5:49 PM |
I've just bought 36 DELUXE p/u equiped with a .radio,but no antenna,i've researched history of truck (i'm third owner) 2nd owner has known truck for past 48 years and was personaly aquainted with 1st owner (a Ford dealer)in Calif.Radio has always been in truck. My info says antenna was mounted under running board?? Is this true? Have you seen one? What does it look like? It was not mounted on cowl. Thanks for Info
trjford8 | -- 05-26-2010 @ 8:31 PM |
In 36 the antenna was mounted in the sparetire cover on the passenger cars. It may be the same for pickups.
nelsb01 | -- 05-27-2010 @ 7:23 AM |
The post you got from Don Rogers with the radio antenna diagram was posted on the Ford Barn. If you need further information you should contact Don Rogers.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=1303 |
