49fordv8f4 | -- 05-02-2010 @ 3:04 PM |
I am in the process of restoring a 1949 F4 truck. The original cowl to fender seal on my fenders is an extruded rubber seal that appears to be of the same material as a windshield or back glass seal and the same profile as the cowl to fender seal,(21C-16068) for a 1942-47 truck. It is also stapled to the flange of the fender like the 42-47 seal. All that I can find is the 7C-16068 seal which is a foam rubber material like a door weatherstrip. The 42-47 seal would work but they are cut too short for the 49-52 fenders. Thanks, Mark Poley This message was edited by 49fordv8f4 on 5-2-10 @ 3:05 PM
Big Red 51 | -- 05-03-2010 @ 6:12 AM |
carpenter has the fender welt in rubber or black vinyl. 48-16070-RR or 48-16070. This should work.
Big Red 51 | -- 05-03-2010 @ 6:14 AM |
Mark, Forgot, rubber is in 8 foot lengths and vinyl in 30 foot rolls
49fordv8f4 | -- 05-03-2010 @ 5:40 PM |
Thanks for the reply Big Red 51, The seal you mentioned has a round bead that is exposed between the fender and body after it is installed. the gap between the cowl and front fender on the 48-52 trucks is too large for that seal to cover. The seal on my truck is "T" shaped.The top of the "T" is about 1/2"-5/8" wide and is what you see when you look at the juntion between the fender and cowl. The leg of the "T" is about 1"-1 1/2" long and is stapled to the fender flange. The 42-47 fender to cowl seal is the same , but I can't find anyone who will cut me a pair long enough for my 49 truck. They are about 6" longer than a 42-47 seal and they all come precut for a 42-47 truck. Thanks Again, Mark
TomO | -- 05-04-2010 @ 7:03 AM |
Mark, try Metro Moulded Parts. http://www.metrommp.com/ Or Lynn Steele. http://www.steelerubber.com/ They make a lot of the reproduction rubber. Tom
49fordv8f4 | -- 05-04-2010 @ 4:05 PM |
Thanks Tom, I contacted Metro Moulded parts and they had the seal I needed in stock, sold by the foot. So I was able to order just what I needed and it shipped today. Thanks Again, Mark
TomO | -- 05-05-2010 @ 7:30 AM |
Glad to help and that you were able to get the needed part. Tom
51f1 | -- 05-07-2010 @ 1:08 PM |
The truck seal is especially made for the '48-'52 trucks and is a sponge type material which allows the front fenders, grille, radiator, etc., to move as a unit independently of the cab. It's a poor design, but it's a Ford! (Maybe it was a better idea?) The same set-up was used on the '53-'56 trucks, I believe. Carpenter and lots of others sell the seals. Steele does not make Ford parts. Richard
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=1181 |
