totalchefen | -- 04-19-2010 @ 9:31 AM |
HI I have to take the left rear tire, the inner,on a Ford Truck 1940 1 1/2 ton. The exterior was not a problem But the next the bolt, square, threaded, the delete? left threaded? Can anyone give me some tips how to do ?
alanwoodieman | -- 04-20-2010 @ 6:59 AM |
if it is like my old 50's truck there is a square head bolt that removes in the same way the larger outer nut does, otherwise tightening the outer nut would loosen the inner nut, there is a special socket that fits this square bolt-do not try to use a big adjustable wrench it will round off the nut-experience!!
supereal | -- 04-20-2010 @ 9:16 AM |
The inner fasteners on old dual wheel trucks are, more often than not, well rusted in place and tough to remove. It will likely require a square socket and a strong impact air wrench to break it loose. If you don't have access to those, I suggest that you take it to a tire shop to have it removed before you damage the studs. Some anti seize compound on the threads will help you the next time you need to pull the wheel(s).
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=1120 |
