krhall | -- 08-19-2017 @ 5:25 AM |
where is serial number or vin located on 29 a pickup?
CharlieStephens | -- 08-19-2017 @ 10:07 AM |
This site is dedicated to Fords from 1932 to 1953. You would have better luck posting in the Model A Forum section of fordbarn.com. Having said that, go to http://jmodela.coffeecup.com/numbers.html for the location of your VIN (serial number). Charlie Stephens
krhall | -- 08-19-2017 @ 10:48 AM |
ok thanks i will but i also have a 32 same problems .lol
CharlieStephens | -- 08-19-2017 @ 1:55 PM |
The '32 had the VIN (serial number) stamped into the top of the left frame rail near the steering. Unlike the Model A this number is visible without removing the body. This is the number the DMV will want to use and should match your title. For the four cylinder the number also appears on a boss on the flywheel housing. For the V8 the number was also stamped into a boss on the transmission case. This number usually appears two additional places on top of the left frame rail under the body. A more detailed information may be found at http://www.vanpeltsales.com/FH_web/flathead_serialnumbers.htm Be sure to read all the way to the bottom of the page. Post what you find blocking out the last 3 digits with "XXX" if you prefer. Charlie Stephens This message was edited by CharlieStephens on 8-19-17 @ 9:16 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=11105 |
