haro | -- 08-06-2017 @ 6:16 PM |
Hello Gang, I have a 1934 one & one half ton truck chassis with running gear that needs a home. Most people tell me to scr*p it but I hesitate to scr*p the running gear. The truck is located in NE Missouri. Thank you for your help.
carcrazy | -- 08-06-2017 @ 9:55 PM |
There may be a museum somewhere that would be interested in having it in a display.
MGG | -- 08-07-2017 @ 6:56 AM |
haro - please enable your private messaging option. I would like to correspond with you about the chassis.
haro | -- 08-10-2017 @ 8:05 PM |
found out about the message restriction. Have it set to receive private messages. Thank you for your help & interest.
MGG | -- 08-12-2017 @ 12:13 PM |
I have a 1934 1 1/2 ton which I think may have a bent frame. Do you have pictures of yours that you could send me by private message?
haro | -- 08-14-2017 @ 8:46 PM |
No, I don't. The wheelbase seems short, maybe around 144 inches? The rear frame horns end a little beyond the spare tire carrier. The frame I believe is straight & true.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=11056 |
