fordtruck41 | -- 05-19-2017 @ 8:23 AM |
I recently purchased a 1941 Ford truck with a stock six cylinder flathead and standard three speed transmission. My question I need to tow the vehicle about 200 miles and need to know if a tow dolley , front two wheels off the ground will be ok and not damage the transmission. Thanks..
alanwoodieman | -- 05-19-2017 @ 10:48 AM |
closed driveshaft- just need to check that the trans and rear end are full 3/4 ton and up just disconnect the driveshaft
carcrazy | -- 05-19-2017 @ 12:38 PM |
This sounds obvious but make sure the transmission is in neutral before starting the journey!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=17&Topic=10769 |
