fordmerc | -- 08-02-2016 @ 11:18 AM |
Replacement weatherstrip for the rear quarter windows seems unavailable for my town sedan. has anyone tried to modify the Ford item to fit the Mercury? I assume the Mercury window is larger, but if the difference is behind the hinge post, couldn't an extension be fashioned and inserted? Any other solution to a leaking gasket would also be appreciated.
TomO | -- 08-02-2016 @ 5:50 PM |
My memory may be playing tricks on me, but I remember this question being asked about a 40 sedan and the Ford was almost the same. I tried searching and could not find the topic. Edit I did find the topic http://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=7038&keywords=quarter%20window Metro Moulded Rubber used to have a write up on how to use their moldings to make your own. If the Ford ones will not work, you could give them a call to see if it is still available. Tom This message was edited by TomO on 8-2-16 @ 6:01 PM
fordmerc | -- 08-03-2016 @ 4:52 AM |
Thanks for info. I will pursue the lead.
Chascwell2 | -- 08-05-2016 @ 5:00 PM |
1940 Ford 4 door sedan rear flipper windows are exactly the same as 1940 Mercury, so I am guessing 39 are the same also. chascwell
shoebox | -- 08-07-2016 @ 7:13 AM |
This would be great news if 39 Ford sedan rear flipper rubber is the same as 39 Merc, CAN ANYONE VERIFY THIS?
TomO | -- 08-08-2016 @ 4:33 PM |
The 39 and 40 Mercury bodies are identical so the 40 Ford should fit your 39 with minor modification. See the topic that i gave you a link to. Tom
shoebox | -- 08-10-2016 @ 4:44 PM |
Thank You, Thank You, Thank You!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=9952 |
