Peder D | -- 09-13-2015 @ 3:33 AM |
Hi again! A while back, I had my speedometer out to inspect a non-working odometer. No luck "mending" that problem. After installing, the speedometer was showing running "correct" at 30 mph using a GPS. Higher speeds and the needle hardly budged. Have oiled the unit where applicable. Tried adjusting the arm, but to no avail. My mechanic implied I would probably need to get it "magnetized" again?...who in the U.S. does professional and reliable repairs on these old Walthams? Thank you! Peder
TomO | -- 09-13-2015 @ 7:41 AM |
Bob's Speedometer Service has a good reputation. http://www.bobsspeedometer.com/1/120/index.asp Have you looked for a speedometer service in your country? You may be able to find one closer to home and it would be more reasonable than shipping half way across the world. Tom
Peder D | -- 09-13-2015 @ 11:29 AM |
Thanks Tom...will also be getting in touch with a local "source" here on Monday morning...if no go here, will try Bob's...
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=8975 |
