clorenc | -- 06-25-2015 @ 11:28 AM |
I recently acquired a 46 Merc that has been sitting for 20 years and am now trying to figure out how to get it running again. There is an On/Off lever right next to the ignition switch. What is it for? When flip it on it makes a growling noise under the hood.
cliftford | -- 06-25-2015 @ 1:29 PM |
I believe you are talking about ignition on-off switch. The lock cylinder you see locks this switch and the steering column. The noise you hear could be a heater or defroster motor running or trying to run, or a number of other things. Try to isolate the noise but don't leave the ignition on for too long, in case there's a short some where.
clorenc | -- 06-25-2015 @ 1:42 PM |
Makes sense. The lights don't go on but the gas gauge responds with the switch on.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=8663 |
