shoebox | -- 04-19-2015 @ 6:58 AM |
Just wondering where I could look up the paint code for the dash paint for my 39....... or if anyone knows it? Thanks much, Shoebox
TomO | -- 04-19-2015 @ 7:20 AM |
I would contact the Club's 39-40 Mercury adviser. He may know the modern equivalent formula. You could also try Jimmy Chips at TCP Global, as they may have mixed it for another restorer. http://autocolorlibrary.com/ Tom
shoebox | -- 04-21-2015 @ 4:06 PM |
As always, thanks for the response Tom. I tried to contact the Merc advisor previously (different subject) with no luck, may try again. WILL contact TCP Global. Regards, Shoebox
fordmerc | -- 05-16-2015 @ 5:42 AM |
Maybe this will help: Gary Slurkanic matched the dash paint on my '39 in an area where it had not faded. IMHO the result is perfect. (I don't have an image of the new interior! -I can get one if it would help.) The formula used is: AZKO paint for the Dash 0.2 L. 92M 77 g 22 9.6 g 37 14.6 g 90M 16.6 g 35 17.5 g 93P 20.1 g 23 5.0 g
fordmerc | -- 05-16-2015 @ 5:52 AM |
here is an image of the can of paint in case the formula is insufficient - the paint color as seen on the can is not representative as it appears on the dash
shoebox | -- 05-20-2015 @ 3:57 PM |
FordMerc Thank you so much for the response and information! I will take your info to my local body supply and see if they can mix me some paint! Regards Shoebox
shoebox | -- 06-05-2015 @ 4:26 PM |
fordmerc, Thank you so much for your info!! I took your formula to local body shop supply and what they mixed up just NAILED IT!! Shoebox
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=8428 |
