jerandbee | -- 05-18-2014 @ 7:26 PM |
Does anyone have the DuPont paint number for the grey-blue dash paint for a 1940 Merc?
TomO | -- 05-19-2014 @ 2:47 PM |
I had to custom mix the paint for my car. I do not have a cross reference to a modern formula. The Ford number for Seamist Metallic is M-1793. When I mixed the paint, I did not have a formula, so we just mixed colors until we got a match to the glove box door that had been out of the sun. There was a company called Color-Rite that said they had the dash color in spray cans, but I think that they are out of business. Tom
jerandbee | -- 05-19-2014 @ 9:53 PM |
Gosh Tom, thank you for sure!!!! Big help - I will now have something to search for with a name and Ford number. If I find anything I will post on the Forum Jerry
jerandbee | -- 05-19-2014 @ 10:15 PM |
Tom, Your help found the dash paint - It is available from TCP Global phone 858-909-2110 in quarts or gallons - price is $52 a quart approx. their number is RSP-AE-D acrylic enamel - use the Ford Number of M-1793 Sea Mist Metallic and it comes up. Thank you so much. Jerry
TomO | -- 05-20-2014 @ 6:32 AM |
Jerry, ask for a sprayout sample before you buy the paint. I bought the heater paint from TCP Global and it was way darker than the heater should be. The heater was a light gray and the TCP paint was a dark gray. I had to take it to a body shop friend to correct the sample. See if you can just get a pint of the paint, I used less than a half pint doing the dash and steering wheel twice. The dash got scratched while waiting to be installed and the steering wheel repair had to be done over. Here is a photo of my dash, before installing it in the car. Tom
jerandbee | -- 05-20-2014 @ 7:23 PM |
Dash looks great - I will try and get a pint of the paint or at least a color chip or something from them. I got a quart of lyon blue for touch up and it came right on the money. as time permits - can you send a pic of the little plastic know that goes on the on/off ignition switch - need to fabricate one and can't seem to find out what they should look like. Thanks for all your good advice.
TomO | -- 05-21-2014 @ 7:18 AM |
My car is a late car, July 1940 time frame and did not have the plastic knob on the ignition switch. I sold my other car that was earlier, and I don't believe that it had a plastic knob either. Try contacting Dan Kreible, the 39-40 Mercury advisor, to see if he can clarify this point. If he cannot, then you will have to contact the Archives for the engineering drawing of the knob. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=7337 |
