Gasolinealley | -- 06-27-2013 @ 11:01 AM |
I am new to your Forum, congrats to all. I am installing a '47 Mercury 59A into my '34 Ford. What do I need to do to make the motor mounts work? I don't want to do any welding on the frame if possible. Thanks to all in advance!
supereal | -- 06-27-2013 @ 3:06 PM |
If you are using the original transmission, use the stock mount. If not, some adaptation will be necessary.
Gasolinealley | -- 06-27-2013 @ 8:54 PM |
Thank you Supereal. Need to research this more, the mounting hole are off about 1-1/2". I am using the original trans and was hoping someone made a bracket that would make the connection.
TomO | -- 06-28-2013 @ 7:05 AM |
You will need Bob Drake's motor mount adapters to raise the front of the engine. http://www.bobdrake.com/ItemSearchForm.aspx?Search=41a_6023 Also you might want to review the post on the the "Clutch pressure plate Clearance 33 trans" The centrifical weights on the 6 bolt pressure plate may strike the inside of the transmission bell housing. You might post this in the General Ford discussion, as more people read that forum. Tom
Gasolinealley | -- 06-29-2013 @ 5:00 PM |
Thank you TomO. I'll check that post out, Thanks
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=6231 |
