tubetype | -- 05-16-2013 @ 11:46 AM |
can a member recommend a site to obtain headlight assy. Thats the two pieces that sit just inside the fender. (41 merc) I think the ford would use the identical units. Thanks.
supereal | -- 05-16-2013 @ 3:11 PM |
The parts your are describing is an assembly called the "headlight bucket". The only ones I found are in the C&G catalog. None are listed specifically for the '41 Merc, but there is a listing for '40 Merc, 01A-13026. I don't have a Merc parts list, so I can't determine the interchange. My friend, Tom O, monitors this section, and he may be able to see if it is a match. In any case, they aren't cheap, at $112.50 each.
TomO | -- 05-27-2013 @ 5:48 PM |
The headlight buckets in the 40 and 41 Merc are different. The 41-48 Ford and Mercury use the same bucket P/N 51A-13008. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=6050 |
