oldguy | -- 08-16-2012 @ 9:59 AM |
Hi, I am looking at some spec sheets and I see with the Merc motors, they refer models as " CM " on the 1949/1950-53 motor, but on the 1950-51 motor it is called "type" and identified as " 1CM " ? I am assuming the " M" is for Mercury, but what would the " C " and " 1 " be refering to ? Thxs Oldguy
Dale Fairfax | -- 08-23-2012 @ 5:59 AM |
Actually the "C" is Ford's code for Mercury. A '49-'50 engine is an 8CM-the "8" coming from 194"8" when the design was introduced. 1CM represents an updated design from 1951. In 1952, the code became EAC.
oldguy | -- 08-27-2012 @ 12:34 PM |
Hey Dale, Just got in and read your reply to my question. Thanks a lot for this info. Always learning Thxs again Oldguy
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=5074 |
