39mercury | -- 05-28-2012 @ 8:18 PM |
I have the 39 repainted. I will be sending pictures later. Now that it is all straight and shiny black again I need to turn some attention to the motor. It ran great, then started running rough. I pulled the plugs and they are all fouled and sooty black. Not greasy, just sooty. That usually means it is running too rich. However I thought it may need a new coil too since it was running well then started to miss while driving it last fall. The wires are new. So I changed the coil too. It started up right away and ran 30 seconds then died and would not restart. I put the old condensor back on and it did the same thing. I have not put the old coil back on. When I check the carb bowl while cranking it I see fuel entering. I am stumped. Should I rebuild the carb? Thanks for any advice you may have. Steve Middleton
TomO | -- 05-29-2012 @ 8:05 AM |
You should not see fuel entering the bowl when cranking the engine, unless you are operating the accelerator. Your float is probably set too high. If you have the steel tipped needle set your float to specs. If you have the rubber tipped needle set the float 1/32" to 1/16" lower. If you have the gross jet (the one with the little ball in the window) set the float 1/16" to 3/32" lower. Before you mess with the carburetor, it is best to solve the reason that the car will not start. Check your spark by holding one of the plug wires near a head nut (use a small screwdriver with an insulated handle. Insert the blade in the plug wire end). If you have no spark, check the input to the coil. The voltage should go from battery voltage to around 3.5-4.0 volts when the points are closed. If you have a weak spark, change the coil. Tom
39mercury | -- 05-29-2012 @ 8:39 AM |
Thanks Tom. I will check this out per your instructions starting with the presence of any spark. I will let you know what I find. Steve
supereal | -- 05-30-2012 @ 11:16 AM |
You didn't mention whether the distributor points have been checked or replaced. One set of points "makes" the circuit, the other "breaks" it. If either set is making poor contact, rough running, if running at all, is likely. This is not rare when a car hasn't been run for a long time. Fuel will enter the bowl while cranking if the fuel level is low enough to open the input needle. If an obstruction is holding the needle off the seat, the carb will flood. This can result in rough running and very hard starting, and sooty plugs.
39mercury | -- 06-04-2012 @ 8:43 AM |
First thanks for all the comments and technical help. Here is the update. Checked the spark by grounding a plug wire to the block while cranking the engine. No spark. Removed the distributor and found that the points were burned. So we cleaned off the contacts and put the distributor on the block with a jumper from the battery and spun the rotor. Sparks inside!! Put the distributor and coil back on the engine. Hit the starter and it fired right off and runs great.
TomO | -- 06-05-2012 @ 6:30 AM |
Glad that you fixed it. Now you can enjoy driving it this summer. Tom
39mercury | -- 06-05-2012 @ 8:38 AM |
Attached are some images of the before and after for the 39 Mercury 99A Town Sedan. This message was edited by 39mercury on 6-5-12 @ 8:40 AM
Mercury8 | -- 11-08-2012 @ 8:27 AM |
Greetings: I have a 40 Mercury coupe, currently doing a body off restoration. When I first bought the car, I was having some of the same running and shutting down problems you are having. From the electrical standpoint, my problem traced down to the most overlooked, yet very crucial, resistor. A bad resistor can work fine, and the reduced voltage will show correct. As soon as you turn your back, the voltage will drop and shut you down. Wait a few minutes for the resistor to cool, and the problem goes away. In the meantime, you change the coil, wires, condensor, points and what else, then the problem surfaces again. The resistor is so often overlooked. From a fuel problem, my car turned out to have a 37 intake manifold, that was burning up the power valve in the carb with hot exhaust gas. The burned power valve would allow un-metered fuel to drip into the intake, causing a rich condition, and rough running. Just a thought. Good luck, leave me an email and we can chat further. Alan
RogerMitchell | -- 01-15-2013 @ 12:49 PM |
I have a 1940 Mercury town sedan that I just finished restoring. I rebuilt the carburetor and after that it wouldn't idle worth a darn and ran rich. Turned out that the new power valve had a bad diaphram and was leaking fuel from the carburetor fuel bowl directly into the intake manifold. I got a new one at NAPA and it has run fine since.
TomO | -- 01-16-2013 @ 7:30 AM |
Roger, Welcome to the Forum. Tom
supereal | -- 01-16-2013 @ 10:58 AM |
Be aware that many of the carb kits being sold are not "fuel proof" for the new gas. Many also have weak accelerator shaft springs and other inferior parts. The best advice is to not fool with your carb unless you are having problems. If you do need to rebuild it, get parts from a vendor that sells lots of them, or have a pro do it so the throttle shaft can be properly bushed, and the power valve fitted to the boss on the carb bowl. Many replacement valves will not seal properly because the gasket flange doesn't match the valve face, causing fuel leakage and loss of vacuum to the valve.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=4719 |
