Peder D | -- 10-21-2010 @ 12:50 AM |
I'm attaching an image of 2 parts that were dismantled in conjunction with among others an inspection of the steering box. Can anyone help me identify these? Have forgotten where these should be mounted? I seem to recall that these were mounted around the steering column going through the floor board, but can't figure out the smallest part? Thanks, Peder
TomO | -- 10-22-2010 @ 7:57 AM |
Peder, it is always a good idea to photograph everything before and during disassembly. I am going to guess at the position of the 2 pieces, based on the description in the parts catalog. The long piece P/N 11A-7001748 goes below the steering column to support the floor board. The smaller part, P/N 19A-7012155 goes above the steering column to support the rubber seal. If I am incorrect, maybe someone with a 41-48 Mercury will correct me. Tom
Peder D | -- 10-22-2010 @ 1:24 PM |
Thanks Tom, I will check this out ...Peder
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=2038 |
