bobb | -- 07-12-2024 @ 12:18 PM |
Any recommendations for an easy automatic transmission installation into a 47 mercury?
carcrazy | -- 07-12-2024 @ 1:18 PM |
Flat-O-Matic offers a kit to allow you to bolt a Ford C-4 Automatic Transmission to your Ford/Mercury Flathead V-8 Engine. https://flat-o.com/car-products/flat-o-matic/
trjford8 | -- 07-13-2024 @ 7:18 AM |
i believe that Speedway Motors also has a kit. If it were me I would go with the Flat-O-Matic as I have used that kit. Also you will get good tech help if needed.
CharlieStephens | -- 07-13-2024 @ 1:21 PM |
Remember that you also will need to work with the rear end. If it was mine I would leave it alone and rebuild the stock box if necessary. Keep going and before long you will have a real "street rod". Charlie Stephens
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=17136 |
