Moon-Man | -- 07-15-2023 @ 7:17 PM |
Is there a trick to removing wheel skirts?
carcrazy | -- 07-15-2023 @ 7:25 PM |
Yes, what kind of car do you have?
Moon-Man | -- 07-16-2023 @ 6:25 AM |
It’s a 1947 Mercury 79M coupe. Advice is much appreciated, as I’ve never had them off, and the tire has a slow leak that is not going away.
carcrazy | -- 07-16-2023 @ 4:41 PM |
Use a small shop mirror and a flashlight to look up inside the area between the tire and the skirt to see what the release member looks like. The handle(s) to release the skirt will either be a flat bar or a round heavy wire-like item. Once located, determine in which direction to move the item to remove the skirt.
Moon-Man | -- 07-16-2023 @ 5:49 PM |
Thanks, I just don’t want to drop it!
carcrazy | -- 07-16-2023 @ 8:20 PM |
Put a folded up blanket on the ground under the skirt before attempting to remove it. This will protect the skirt from being damaged while you remove it.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=16551 |
