Displayman | -- 08-08-2022 @ 8:25 AM |
I can't find the vin number on our 1947 Merc. convert. Checked the driver's side frame rail. Used a brass brush to remove paint, no number. We have another 47 Merc. convert, and the number is on the driver's side frame rail. I checked the trans slot , and found another vin number from 1946. appreciate any thoughts or ideas. Thanks, Bob(Displayman) Hampshire, Ill.
trjford8 | -- 08-09-2022 @ 7:04 AM |
Did you check the entire top of the left rail from cowl mount to past the front crossmember? I have seen those numbers go past the front crossmember.
Displayman | -- 08-28-2022 @ 8:08 AM |
Thanks for your input. Bob
Displayman | -- 08-28-2022 @ 8:54 AM |
Found the vin number in the front location like you had said. A BIG thank you, again. Bob
trjford8 | -- 08-29-2022 @ 7:05 AM |
You are welcome and glad you found it.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=15857 |
