bigb609 | -- 06-14-2010 @ 5:10 PM |
Hello just wondering if anyone would have the New or updated)part number for the front shocks on a 47 Merc Coupe took the old one in with the part # and the called monroe but the # they provided is wrong Thankx Brent
trjford8 | -- 06-14-2010 @ 6:20 PM |
The Merc would use the same shock as the Ford in late 47-48. A good parts house should be able to look at the mounting points and check the extended and compressed lengths and come up with a shock that will fit.The Ford part # is 7RC-18125-A. You might try a Napa store as they carry a lot of early parts. You might also call C and G Parts at 1-800-266-0470, they have the shocks in stock. This message was edited by trjford8 on 6-14-10 @ 6:23 PM
bigb609 | -- 06-14-2010 @ 7:44 PM |
Thankx Any tips on converting the rear to tube shocks suggest one conversion kit over another Thankx Brent
supereal | -- 06-15-2010 @ 8:30 AM |
That is a bigger job than the fronts because the rear hubs and drums have to come off to install the lower brackets. C&G has them (800/266-0470). Part # 11A-18125-KIT. Catalog says $212.95. Good quality never comes cheap.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=1393 |
