coup | -- 11-04-2016 @ 8:11 AM |
Need to know where to mount the controls. Thanks Neil
TomO | -- 11-05-2016 @ 8:15 AM |
Do you have an overdrive or a Columbia? If it is a Columbia, what controls are you asking about? Tom
coup | -- 11-05-2016 @ 10:01 AM |
Columbia 2 speed . the electric operated solenoid to switch rear gear. Thanks
TomO | -- 11-05-2016 @ 7:46 PM |
The solenoid is mounted on the driver's side of the firewall. I cannot give you the exact location, but if you contact John Connellyat Columbia 2 speed parts, I am sure that he can help you. http://www.columbiatwospeedparts.com/Pages/default.aspx Tom
coup | -- 11-14-2016 @ 5:27 AM |
Thanks. I found a picture showing a rod connected to pedal. This message was edited by coup on 12-8-16 @ 7:47 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=16&Topic=10237 |
